Alternator bracket help
brad1982
I have A 96 grand am GT 4 cyl. I need to put a extra alternator in it and I was wondering if anyone knows if you can get custom brackes that will bolt right in the car or if the car has to be brought somewhere to get the brackets specialy measured and maid for the 2nd alternator?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5385
you'll need to take the car to a metal fab shop along with the second alternator and have the brackets fabricated.
Username: Kester
Post Number: 14
brad1982
curious... what size amp output is your original alt?
brad1982
My stock alt. is 105amp
