Experimental amplifier: Input needed
Username: Tecpc2001
Can someone give me input on a class D amp, tested with these specs...
Mono BASS Amp Specifications
RMS Power at 14.4V (into 1 ohm 50Hz THD+N < 5%) 1211 Watt
RMS Power at 14.4V (into 2 ohm 50Hz THD+N < 3%) 920 Watt
RMS Power at 14.4V (into 4 ohm 50Hz THD+N < 1.6%) 600 Watt
Efficiency (Full Supply Power TO 400W Output Power Ratio (c=PE/PO)) > 80%
S/N Ratio Full Rated Power (Level at Max, A-Weighted) > 80dB
Low level inputs 0.2V--5V
Frequency Response (0dB/-3dB) 14Hz--220Hz
Crossover Low Pass Filter 25Hz--200Hz
SUBSONIC Filter 20Hz-50Hz
Low Pass Filter 24dB/Oct
SUBSONIC Filter 12dB/Oct
Phase shift test at 100Hz 0--180 DEGREE
Operating voltage DC10V--16V
Remote control Optional
High-grade Nickel-plated, heavy duty terminal block type connectors Yes
protection Short circuit, Overload, over Thermal
Dimensions (HxWxD) 200mm x 60mm x 400mm
Thanks
Username: Boopers
Lima, Ohio United states
Post Number: 242
scary thd's on it if you ask me
Username: Tecpc2001
The distortion would be barely audible
Wouldn't it...
http://www.bcae1.com/thd.htm
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5353
looks like they gave honest specs.. for once on an amplifier.
wish they said how they tested THD and power etc though.. if it was using FCC or IEA standards.
those are actually very typical distortion levels for full output on a class D amp.
keep in mind though, distortion spikes when you get close to peak output from a class D amp, so it should decrease substantially at normal listening levels.
