Question for glass on jbl 600.1 at 1 ohm
Username: Thumprms
DaltonUSA
Post Number: 49
if the jbl puts out 300 rms at 4 ohms and 600 rms at 2 ohms, would it put out 900 rms at 1 ohm?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5319
In an ideal world, when you halve the impedance (load) you double the power, so it would be 1200 watts.
Now, you lose some to heat, inefficiency etc so really power never doubles.
With the JBL, being a class D amp, output is regulated at 1 ohm, so the 600.1 puts out the same power at 1 ohm as at 2.
short answer, it's 600 watts at 1 ohm as well as at 2 ohms.
The same holds true for the 150.1, 300.1, and 1200.1, where power is the same at both loads.
This is a feature of the BP series mono amps.
Username: Thumprms
DaltonUSA
Post Number: 50
thanks glass
