Watts?
would a JBL bp1200.1 be enough to power 2 12" Adire Brahmas in a Powered 4 Sound Double Shot
Username: Audiobahn_man
Freakmont, MI
Post Number: 238
you would be underpowering them....
i heard they only need 600 watts to reach X-max though? and this is in a ported enclosure
Freakmont, MI
Post Number: 243
well If you have enough money i would do it IMO, but if you want to save some you could replace the 2 12's with 1 15...that would be hella loud
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5333
the JBL would be fine.
You are correct about the amount of power needed to reach peak output.
Increasing the power will only cause them to reach full output at a lower system volume really.. which will only help if you want more bass in the music at lower levels.. this is mostly helpful if you want "feel it" bass at very low volumes.
More power won't help in reaching a higher SPL much though, since at high volume you're going to be at full output from the subs anyway
