Mtx 421 d any good?
Username: Lighting_boy
Post Number: 14
http://www.cardomain.com/item/MTX421D
also any of these good?
http://www.cardomain.com/item/LITB23501
http://www.cardomain.com/item/JBLBP6001Z
http://www.cardomain.com/item/JBLBP12001Z ( cheap?)
NeedyourHelp
What sub are you going to use the amp on? what ohm load your sub wired, and so on...
But as for those amp, I would get the bp1200.1z, it comes w/ 1 yr warranty if I'm not wrong. You can not find any deal better than that. the bp1200.1 is one of the most recommand best bang for your buck amp I have seem over a few forums.
And one of the great thing about this amp, it has the some output at 1 or 2 ohms. There is a lot more good things about the amp.
I personally have NOT yet owned one but looking to get one in the future. Try to listen to it yourself if that's possible, nobody know you better than you.
Anyhow, good luck!
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5373
deja vu
thought I answered this one.. somewhere..
anyway, JBL, MTX good. Lightning bad.
