Are the alpine Type X components any good? They look like they come with a small LCD screen to control them on the site. One more question; When you get brand new subs do you need to "break them in" or can you start bumping right away?
the type X are well made. if you like them is up to your ears. breaking in subs, you usually want to keep new subs at low to moderate volume for the first 20 hours or so.
guest
20 hours!! Man that is going to be hard !! Is there anyway to use my laptop for playing mp3s and other audio media file formats over my car stereo?
