How to read specs
Username: Alex711
Post Number: 41
How do u tell how loud a sub is by reading the specs..i don't understand all the stuff..just want to be able to tell if what i'm lookin at is gonna be loud or not.???
Username: Elecgenius
La Puente, Ca United States
Post Number: 87
the sub usually has an spl reading. most of them are not eveen accurate though. people mostly go by the rms wattage of a sub. i think knowing what the abbreviations stand for on the spec will help u out a bit. http://www.teamrocs.com/technical/pages/terms.htm
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5330
the "SPL" rating and power handling both are meaningless in this case.
if you want a rough idea of the SPL a given speaker is capable of then look at the cone surface area (or diameter) and the Xmax or excursion.
That's a very rough way to tell.
There is no perfect way to know how loud a sub will be though since it's based on a LOT of factors.
sub design, xmax, enclosure, vehicle, power, and plenty more.
