Like
XM satellite radio car antenna
Username: Jhanna
Cats chewed a hole in the insulation on my Delphi XM antenna wire. Taped over it but it will not work. Still have plenty of wire, any way to splice/reconnect?
Username: Davidmeyer
Oshkosh, Wisconsin United State...
Personaly, I would just go out to your local Radio Shack and buy a new antenna wire.
Did they chew through the wire or just the insulation on the wire.
You could cut a section of wire from bothe sides of the damaged area and reconnect the two ends thus removing the damaged area, leaving you with one whole undamaged wire.
Username: Pat_l
Tucson, AZ USA
Post Number: 143
Yeah, its just like water pipes, if there is a crack or leak then you cut the section damaged out and then use new filler pipe with connectors to repair. In your case you probably just need to cut the section out and do some taping and your good.
Facebook
Shop Related Deals
Directory
