Confused on the wiring on my amp, can anyone help?
Username: Djzavala
Whittier, Ca USA
Post Number: 51
Im trying to set up my subs, but i dont know exactly how, looking at this diagram for a 4 ohm load i cant finish it.
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=21&image.y=15
i have a Fosgate Power 851s amp (2 channel amp). Im confused because in the picture there only ends up being 2 coonections to the amp, one positive, one negative, (because the subs where hooked up together to parallel or series, dont really know) but where do they go on the amp? my amp has 2 sets of positive and negatives (obviously the left and right speakers)
Username: Djzavala
Whittier, Ca USA
Post Number: 52
when you go to the link, select 2 subs and 4 ohm Dual VOice Coil
Username: Insearchofbass
Post Number: 981
you have to hook the subs up to your amplifier in bridged mode. Your amp should have indicators on the side of your speaker inputs. Also make sure to press the bridge button in on your amplifier after youve done this.
Username: Djzavala
Whittier, Ca USA
Post Number: 56
so by setting the subs up the way the link says, i will have set them up bridged? or what set up is it in the link?
Post Number: 982
yes this will be a set up for bridged
Username: Djzavala
Whittier, Ca USA
Post Number: 57
ok thanks, i got it now
