Well i fineally did it. I got 2 10inch rockford fosgate rfd2210 hx2 dvc subs with a rockford p8002 amp. Just wondering what does the dvc mean. I haven't seen it that much. and do you think that will sound good please tell me it will!
dual voice-coil. it means the sub has two coils that will need to be wired together in series or parallel to give you a final load for the amp you choose. if the coils are each 4 ohms, you'll end up with a 2 or 8 ohm sub. this will affect which amp you choose.
taylor
okay now i feel stupid for not thinking of that thinks
