Will my amp power these subs?
Username: Dustin_9
Greenbrier, Arkansas USA
I just purchased two brand new Rockford Fosgate P210s4's (punch 2's not 1's ten inch). I have a RF p2002 amp. I dont know if my amp will be enough to power those two p2's so if glasswolf or someone can tell me if i will be alright as far as power goes. Thanks in advance.
Username: Bumpingloud
Phoenix, AZ USA
How Many Watts Rms are they? And What's your amps specs.
Username: Dustin_9
Post Number: 8
the subs are 200 w rms and 400 w peak power and my amp is a RF p2002 but im not sure exactly how much rms watts to each channel im running, and doesnt ohms have something to do with how much each subs gets?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5152
Rockford Fosgate Punch P2002
MSRP $190.00 US
Channels 2
Per channel power
CEA-2006 compliant
50 W x 2 @ 4 Ohms RMS
100 W x 2 @ 2 Ohms RMS
200 W x 1 @ 4 Ohms Bridged RMS
Total power 200 Watts
Bridgeable Yes
Crossover HP 40-400Hz 12dB per Octave
LP 40-400Hz 12dB per Octave
Tone controls Bass Control
0 to 18 dB @ 45 Hz
Signal input Low level -
Quantity - 1
Type - RCA(pr)
Line output 1 RCA(pr)
Phase control
Power input Connector - Block
Wire gauge - 4
Speaker output Block
Power supply topology
Output topology
Display
Heatsink Type -Cast
Protection
Remote control Included
Type - Wired
Controls - Bass
Class A/B
Marine use
Specifications
Stereo/Mix mono
Frequency response 20 to 20k Hz +/- .5 dB
Dimensions 2.4 X 11 X 11.7 (inches)
even at 2 ohms, you'll only get 199w x 2.
that's not really enough power.
how many coils and ohms per coil for each sub?
Username: Dustin_9
Post Number: 9
I cant tell you. I dont have the subs here i put them on lay away until i sell my other subs. I just need to know if i have to have a new amp to run these subs.
Username: Glasswolf
Post Number: 5159
yes.
you'll need a different amp.
which amp will depend on the subs
