What is the Best Amp for Infinity Subwoofers?
Username: Eejay
Would anyone know what type of amp would be best for a single 12" Infinity subwoofer in a sealed or vented enclosure?
The peak power is 1230 watts and 300 is the RMS wattage.
Username: Dustin_9
Greenbrier, Arkansas USA
Personally i cant afford JBL amps so I would go for the RF p3002 amp puts out 300 w rms if you just bridge it to the one sub and it is definatly a quality amp for about half as much as you would need for a JBL BPX1100.1
Username: Boopers
Lima, Ohio United states
Post Number: 213
what about the jbl bp1200.1z on cardomain or whatever for like 200? or even the jbl bp600.1z for less?
Username: Jonathan_f
GA USA
Post Number: 2497
JBL 600.1 is perfect for those subs.
