2ohms or 8ohms???
Do or Die
What ohm rating would u recommend on running my subs? What are the Pros and Cons
Username: Deathshadow
Post Number: 98
8 ohms = $$$$$$$$$$
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1025
2 ohms you get more power from a mono amp but if you have a 2 channel amp, chances are it wont be able to bridge down to 2 ohms
8 ohms you can use a 2 channel amp but you will have to spend alot more on a more powerful amp to get the power to the sub as you'd need for 2 ohms
