No power
all the amp wire are connected properly just as the amp is also connected properly but when
I turn on my radio the amp does not power up also when i put the fuse in the fuse holder it sparks is that normal can the power cord be to weak to power the amp any help would be great!
Username: Glasswolf
Post Number: 828
yes sparking is normal.
use a voltmeter and test for +12V at the amp for both power and remote trigger.
check ground points for continuity.
thanks Im new to this kind of stuff your help will be very usefull. Thanks
