Stolen vechical help
my 1990 pontiac firebird v-6 was stole and the ignition was destroyed... i need help with the installation on a new ignition that i have purhased... a walkthrough or picture diagram link would be great if you guys can help...
Username: Erus37
Hollywood, Fl USA
Post Number: 9
STEERING COLUMN HAS TO COME OUT
sammysosa
It's hard and you need a lot of tools hope you have the money to spend on a lot of tools that you will never use again...
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5329
get a haynes manual. you'll find all you need there, but if you have airbags or anything like that, you may as well let a dealer do the job or an auto shop.
you won't have the tools needed to pull the steering wheel.
