Question about digital design subs
Username: Hifonics
Post Number: 50
Can any1 tell me if i can do this. Ok first i started building a ported box with two chambers with 2 dd 10" subs, but i bought the 12" 3500 "d" series subs and the ported box is to little. So i was wondering if i can run the subs free air even though i have ports in the box
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1024
free air isnt always a good idea, you're better off spending the time to make even a sealed box for them if ported will be too hard
free air doesnt sound very good and its easy to over excurse a sub and destroy it using the trunk as your enclosure....
you can run them free air but its not a good idea
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5077
running subs with no suspension at all causes them to over-extend very easily, with little power applied.
you'll most likely get very little bass, and end up damaging the speakers.
Username: Hifonics
Post Number: 51
digital design subs will lose how many db if i put them in a box that is 1.2 cu ft small? or could polyfill help me a little
Hfl, Ny Usa
Post Number: 1030
polyfill will help
