99 FORD F150 SUBS ON A STOCK DECK
I have a 99 fore f150 and i am going to put 2 subs in it. the problem is, is that i can't figure out how to wire my amp off of my stock deck. Has anbody alse done this or have any idea on how to do this?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5059
get an amp with high level or speaker level inputs.
then you just tap into the rear speaker wiring for signal
run power to the battery
ground close to the amp to bare chassis metal
no need for remote on most newer amps. they sense the speaker signal and use that to trigger the power on feature of teh amp
