What amp do i need please help!!!
Username: Mikeycaldarone
North Providence, Rhide Island United States
Post Number: 15
i have 3 12" Infinity Kappa Perfects and i need a good amp to run them. Name any price under 500$ and tell me the amp i should run thank you.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5072
depends on the subs.
how many coils and how many ohms per coil for each sub?
what's the RMS rating for each sub?
Post Number: 16
the rms is 350 a piece and im gettin 3 the ohms are 2 4ohms can u tell me with that information
I have a 400w sub 12" what type of amp should i get?
Username: Glasswolf
Post Number: 5162
Mike, the jbl bp1200.1 should do the job.
Vibe
I have bought the AC12T spaced loaded, its 1400 watts rms and 5600W peak. Can anyone suggest any amps that I should consider and would be good with this system.
Username: Glasswolf
Post Number: 5180
Vibe, stop cross-posting, and start your own thread.
Username: Bumpingloud
Phoenix, AZ USA
Post Number: 8
If you get the jbl 1200.1 Glasswolf recommended in another post to spend the extra 6.00 and get the Y splitters 2M to 1F to get signal to all 4 inputs to get the best out of your amp.
