Need help on box dimensions for Diamond CM3 15's
Username: Rainy
Post Number: 29
I cant open the dimensions off the diamond website, and the woofer that I bought does not have any instructions what so ever. If anyone knows either the specs on them, or knows how to fix the problem Id really appreciate it.
thx in advance
Username: Chevy_for_life
Post Number: 122
what is the addy to get to where the demintions of the box should be????all i could find is that Matrix box that it wants u to buy..
tell me the addy to get there..and i will try and help
Username: Rainy
Post Number: 30
diamondaudio.com
I just need the specs on the speakers to figure out the dimensions. Im dlin adobe atm.
