Alpine CDA-9815 and KCA-420i
Anyone know if my cda-9815 will work with Alpine's new KCA-420i iPod adapter?
I am expecting the 420i tomorrow from Crutchfield and hope to have it in this weekend. I am running the 9815 as well in my truck and am told by everyone that it should work. I can let you know what happens if you are interested.
I also own the CDA-9815, and am interested in KCA-420i's compatibility with this unit.
Well gents, just finished installing it. Works like a charm! :-)
It is a complex interface to use on the HU with all the different button combinations. It will take a little time to get use to it but it does work exactly as the demo on the web site explains.
Hope this helps.
Thanks!
Thanks!
Username: Zneon
Durango, Durango Mxico
Hey i like the 9815 but i'm not sure wich is better, the 9815 or the 9833? Any difference?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4532
I think the 9833 replaced the 9813
the 9815 is replaced by the 9835
all four are great units.
I use a 9813 in my jeep and a 7990 in the charger
I installed my new 420i to work w/ my 9815 and i'm getting "error-2" when i try to select the source. it sounds like you all have gotten this setup to work...any idea what's going wrong here?
Username: Zneon
Post Number: 9
try this http://www.talkaudio.co.uk/vbb/showthread.php?t=88882
and go to post #9
WuanTon
Anyone know if the KCA-420i works w/ Alpine CDA-9807? It has the "Quick Search" function and Media Xpander as well as Ai-Net equipt.
unhookt
Anyone on the 9807 know if these are compatible?
