JL12W7AND1000/1 AMP
Username: Doitbig22
Frankfort, Ky Us
I HAVE A 2 JL 12W7 AND ONE JL 1000/1 CAPABLE OF 1000 WHATS NO MATTER WHAT OHM OR WHICH WAY U HOOK IT UP. I AM TRYIN TO SELL THE SUBS FOR 750 PLUS SHIPPING AND THE AMP FOR 525 PLUS SHIPPING OR BOTH FOR 1100 PLUS SHIPPING.
Username: Chevy_for_life
Post Number: 123
that amp is only rated at 1000 watts for 1.5-4 ohm.. so if you run it at 1 ohm u could Fu<k it up..
Rated Power: 1000 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio*: >95dB below rated power
Frequency Response: 5 Hz-500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ: parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter: fully-variable 24dB/octave from 15-60 Hz
Output Polarity Reversal: switch permits instant output polarity reversal
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept 4ga. wire (required)
and sells for 799.99 brand new
Post Number: 124
plus if you run this above 4ohms lets say 8 ohms you will only get 500 watts according to my research..
Username: Doitbig22
Frankfort, Ky Us
O WELL I WAS JUST TRYING TO GET A POINT ACROSS MISTA TECHNICAL DANG WHAT U DO GO AROUND AND CATCH EVERYONES MISTAKES. U PROLLY CANT EVEN AFFORD MY STUFF THATS WHY U HATIN GO ON SOMEWHERE
Username: Deathshadow
Post Number: 49
No one is "hatin" dawg.... If your going to start flaming go somewhere else. You can afford your stuff but you dont even understand its capabilities... lol Your an amateur, probably had your stuff installed for you too. Just kill yourself and stop talking now before you melt everyones minds with your "ill" Ebonics skillz', fo' shizzle dizzle? :-)
Post Number: 127
lol no i just dont want people to be fooled by your mistakes and trust me i can afford it..
