Do these totally suck
Username: Erik123456
Arlington, Tx
Post Number: 175
my 2 12" vmax subs are in a box thats to big for my new civic, im looking for something decently loud that isnt going to take my entire trunk
jl stealthbox isnt made for the 4 door if im correct
i usually bash bazooka but i was wondering how 2 of these would sound if i run them off nice amps
Arlington, Tx
Post Number: 177
bump
Username: Comet345
Orlando, FL USA
Post Number: 78
what does bump mean !?!?
slutho
lol subs go bump...
Username: Slap_johnson
Arizona
Post Number: 78
dont go bazooka, you could go 1 15" V-Max, or 2 12" sealed
Username: Jonathan_f
GA USA
Post Number: 2365
What you could do is take both V-maxes and run an isobaric enclosure, or sell one V-Max and keep the other, either would be better than the Bazooka. Cheaper and better.
Username: Insearchofbass
Post Number: 898
please please please dont do the bazooka and yes id just remake a box for the vmaxes. Also see if you can custom install them other than in just a box and save yourself some room. I dont no what the civics are laid out like but maybe you can squeeze them in a back deck or in a fiberglass setting along the sides of the trunk. I dunno just food for thought.
