audiobahn user Unregistered guest | what do you guys think is the better of the brands for running 2 12' subs what will give me the most power for my money?? |
Bronze Member Username: Chevy_for_lifePost Number: 82 Registered: Sep-04 | I think Kicker...but i've been told RF is pretty good but then again i've herd RF sucks to.. so..lol |
audiobahn user Unregistered guest | yeah kicker i here never gets hot but idk what is a good one like what style |
audiobahn user Unregistered guest | do you have kicker or what?? |
Bronze Member Username: Chevy_for_lifePost Number: 84 Registered: Sep-04 | me? I have a Diamond 1200.1 amp |
audiobahn user Unregistered guest | hey another ? i have is the biger the box you have the better the bass or what ?? right now i have a audiobahn 12' 1208t it is a masive like 270 oz mag and its only in a 1.5 box |
Bronze Member Username: Chevy_for_lifePost Number: 88 Registered: Sep-04 | its best to use the box that is recommended for your sub because to small the air has no where to go but to big and its pointless to have a box... least i think thats how it goes.. someone check me...? |
audiobahn user Unregistered guest | yeah thats how it is but idk what it recommends... |
Gold Member Username: Jonathan_fGA USA Post Number: 2307 Registered: May-04 | JL and Kicker are the best on that list IMO. Both are very underrated, quality amps. You wouldn't be disappointed with either. |
Silver Member Username: Koz1031Monticello, In United states Post Number: 221 Registered: Jul-04 | I've got a MA HK897 1200@4ohms/bridged and it pushes the tremors with no problem. In fact I had to cut the gain back to just under half to stop the clipping, and it's still pretty loud. Even though tthe subs are in a box that they weren't designed for. Plus the price was right. I've had no problems with it as of yet, but I will have to admit it's only like 3 weeks old. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4640 Registered: Dec-03 | of the initially listed amps, I'd go with: JL, Kicker, or RF. probably in that order, too. wouldn't bother with MA or Audiobahn myself. |
audiobahn user Unregistered guest | hey thanks guys |
audiobahn user Unregistered guest | ok another ? is what jl amp to go with i am going to run 2 12' subs they are 1500 RMS each so 3000 RMS in all ok i know all about audiobahn and there over reting but thats what i got and i need to know what would be a good jl amp for thes dual 2 ohms DVC |
audiobahn user Unregistered guest | ne more people want to say what is better kicker or JL???? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4696 Registered: Dec-03 | ok two audiobahn 12" subs rated thermally for up to 1600 watts. in reality they need about 500 watts each maybe. That's to reach peak output. dual 2 ohm coils, so a pair of 4 ohm subs. go to sounddomain.com the JBL bp1200.1 is $200 right now. great amp there, and it'll give ya 600wRMS per sub. all the power ya need for those subs, and save about half the cost of a Kicker amp, and about a fifth of what a JL 1000/1 would cost. |
audiobahn user Unregistered guest | ok now i need to know is it safe to get a factory ref. amp or not??? |
Silver Member Username: FishyTamarac, FL USA Post Number: 573 Registered: Sep-04 | I wouldn't have a problem buyin a factory refurbished amp, of course I buy "used" stuff off ebay as well. -Fishy |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4773 Registered: Dec-03 | really it depends on the product. I'd probably avoid a refurb'ed subwoofer.. personally. an amplifier, or other "solid state" sort of device, sure.. fixing those is just soldering in new parts.. usually they come out as good as new, and offer some limited form of warranty to insure they work. I've bought used stuff on eBay as well as a few refurb'ed items. I've even bought DOA stuff and fixed it myself which equates to a home refurb.. hehe one of my 2250SX amps came DOA.. works like new now. |
audiobahn user Unregistered guest | ok i think this is my last ? are jbl and jl audio the same?? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4793 Registered: Dec-03 | very much no. JL Audio is www.jlaudio.com JBL is www.jbl.com very different companies. JL Audio makes high end car audio gear, mostly in the upper price ranges. JBL makes good stuff, but tends to be more affordable, and not really on the level of JL's gear. |
audiobahn user Unregistered guest | on sounddomain they have jbl and on other sights there are JL |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4796 Registered: Dec-03 | JL Audio doesn't authorize internet sales. if you see JL for sale on-line, it's either used, or it's gray market, and unauthorized with no factory JL warranty coverage. |
audiobahn user Unregistered guest | glass you told me before to get the JBL bp1200.1 is that as good amp or no its also facory referb im willing to pay like 450$ can ne one give me more sugestions on a amp to get? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4798 Registered: Dec-03 | yes the 1200.1 is a very good amp. used plenty of them. |
audiobahn user Unregistered guest | if its that hard to get a jl amp im goin to go with something els got ne more amps you would sugest? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4801 Registered: Dec-03 | JBL is easy to find. JL Audio is waht you have to buy from a local dealer. the JBL bp1200.1 is all over the net. cardomain.com has plenty of them. other options are Kicker and MTX, Cadence, Rockford Fosgate, Avionixx, and Memphis. |
audiobahn user Unregistered guest | i was just readin about problems with thes jbl it sed to use RCA Y spliters and MFOD things is what the only things wrong with them? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 4821 Registered: Dec-03 | nothing is "wrong" per se. the JBL amps even though they are mono amps, offer 4 RCA inputs (front and rear L+R) so if you have 2 sets of pre-outs, you can fade and not affect bass. Something in the amp's design basically makes the amp work best if all 4 inputs have signal, so if you run one pair of RCA lines to the amp, split it at the amp so all 4 inputs have signal from the 2 leads. This makes the amp hit a bit harder basically. as for the FMOD comment, the amp has no built in infrasonic filter. If you're running a sealed bod for subs, this doesn't matter in the least. If you run a ported box, you'll want to go to www.partsexpress.com and order a 16Hz or 25Hz high-pass filter (RCA level) by FMOD. this will block subsonic frequencies from the amp. this is important due to one of the quirks of ported and bandpass enclosures. below the tuned frequency of the box, the subwoofer loses damping, which means the sub could easily over-extend, causing motor damage to the sub. The fix for this is to block those frequencies from the sub, by using a high-pass filter set about a half-octave to an octave below the port's tuned frequency. that's pretty much everything you need to know about it and everything I can think to tell ya. no big deal on either issue really. |
