Power hx2 15" vs. solobaric l7 15"
I LIKE *LOUD*
I am deciding on getting 2 power hx2's 15" ......or 2 l7 15 solobarics .......which do you think would be louder? and what would be a nice amp to go along.
I LIKE *LOUD*
could i get anything louder around that price range?
Username: Glasswolf
Post Number: 796
the two S15L7 Solobarics will be louder, and the Kicker o2KX1200.1 is a good amp.
use two 2 Ohm subs, and run the amp at 1 Ohm. You'll get 600wRMS per sub.
Username: Tlo211
Post Number: 11
just like glasswolf said
4 15" CVR's would be even louder! Thats what I Have in the ext. cab of my 94 dodge dakota! It rocks the loudest thing I have heard around in a long time, I'm runnin 2# 1 farad caps, 2# optima batteries, and 2# kicker 1200.1 sub amps! Bass wise anyway! E mail me if you want to here bout the mids & highs!!!!!!!! Ha! Ha! Ha!
