Blown subs
Username: Jeremy_c
Kirksville, MO USA
Post Number: 9
Is it posible to blow a 500 sub with only an 300*2 watt amp that is not briged
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4930
very easily
http://www.bcae1.com/2ltlpwr.htm
you could probably blow the sub using 10 watts.
if you set the gain too high to compensate for lack of power, you cause the amplifier to "clip" which sends DC voltage across the speaker coils.
this causes the coils to ehat up, and you cook the sub.
result: daed sub.
same thing happens with not having enouch alternator current for the amplifier(s) in high current systems
