>>>I need help..<<<
Username: Domainer
I am REALLY a newbiee at car audio and i need help.. i want help to choose between brands (i.e. kenwood, pioneer, rockford etc..). i want to install a loudspeaker system with a budget of $1000 - $1500. First i will install 4 speakers, a cd receiver and the amp with the sub i will install them later on...so i need help about the speakers and the cd receiver(speakers are more important).
I would be trully thankful if you could help me. ***Don't get into big troubles with models and stuff..all i want is your opinion between brands
Username: Jamtochristian
Williamsport, Pennsylvania USA of course!
Post Number: 173
This is way to vague for us to make recommendations. If your curious what brands are good, check this for reference. Don't complain if a brand like kenwood isn't great. No offense, but fosgate are crap. They used to be descent, way way back. They're new "circuit city" stuff is crap. Kenwood, I don't care what anyone says, they're amps aren't THAT bad. I will stand behind them because I've never, may I repeat NEVER had a problem with a Kenwood amp. But I've only had a few of them... so we'll see on that. anyway, check this list.
http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4830
brands..
the good, the bad, and the ugly:
http://www.caraudiocentral.net/forums/showthread.php?t=32
precisely why I wrote that list.
