Port question...any help is appreciated
jci4
can you change tubular ports for square or rectangle vents by figuring the internal volume of the cylinders andmatching the vent to it if you keep the same depth.
my enclosure sounds good but its not a practical fit in new vehicle.im going to build a new box with different dimensions but same volume, however the old enclosure uses 4-3"x8" ports. if possible id like to swap in those ports for a single rectangular vent..
thanks for any help
Username: Audiobahn_man
Freakmont, MI
Post Number: 190
yes here is the site
http://www.carstereo.com/help2/Articles.cfm?id=31
jci4
thanks steven you are a godsend
