Polyfill???
Username: Aaronmiiller
Post Number: 7
The question is to use polyfill or not to use polyfill in my ported box? To view my box visit www.cardomain.com/id/blazinahrent Im not real sure if i should put polyfill in their or not. If im not mistaken i would have to put chicken wire back inside the box to keep the polyfill from coming out? The question i am asking is will it make my system any louder?
Post Number: 8
One more thing, How much do you think i should put in the box? IF i should at all.
Username: Jonathan_f
GA USA
Post Number: 2286
No, it's not going to make your system louder, what it will do is give the effect or a larger box, which will lower tuning, and you probably know it's harder to hit high numbers with lower tuning. If you want more SPL, then you need a larger box, larger ports, a higher tune, and more power.
