Polyfill in slot ported box
can polyfill be placed inside a slot ported box?
will it affect the tuning of the box any?
Username: Invain
Michigan United States
Post Number: 259
Yeah, I think it should make it a lower tune. I think it's something like a lb of poly fill per fubic foot makes the box seem 10% larger. Larger the box with the same size ports, lower tune. I could be wrong though.
Username: Hiphopanonymous
Post Number: 142
if it's ported, you are going to need to buy the polyfill that is in sheets. then staple them to the sides. if you just put in plain stuffy polyfill, it's gonna be blowing out of your ports.
Username: Aaronmiiller
Ive seen on many occasions where it is recommended to put polifill in ported boxes the only thing is that you need to staple chicken wire of some sort just before the port begins to shoot straight out to hold the polifill in place and it should sound a little better "SO I HEAR!"
