Battery or alt???
audiobahn user
what should i get first a yellow top or a H.O. alt first??
if i fully power my subs it will be around 2400RMS
Username: Jamtochristian
Williamsport, Pennsylvania USA of course!
Post Number: 167
First off, it is often a error to go ahead and just buy a battery and feel that it will fix your problem. Well the problem is that your system probably won't be getting enough power. The alternator is the generator of the amperees that power your stereo, so yes, I definitely recommend this upgrade FIRST!
