Gas pedal down, the crackling begins!
capper
this is for what the threads says its for
Username: Motoman22
Dallas, Texas USA
Post Number: 108
Read the thread 'My car speakers are making a crackling noise' from top to bottom. If you don't know the answer after that, pay a professional to fix it.
Username: Donp
Detroit, MI USA
Post Number: 10
Could be Alternator noise. Make sure you have good ground, tight battery connections, and try re-routing your wires. If all fails, add noise supression.
