Somethings i just dont understand
the sub i am about ready to buy is dual 2 ohm and the amp ihave is 1500 watts x 1 into a 2 ohm load. so can these 2 go together because at teh wiring wizard it showed a 1 ohm load and a 4 ohm load so is my amp 1 ohm???/
Username: Insearchofbass
Post Number: 832
if you want a 2 ohm load you need a dual 4 ohm subwoofer (if your doing one subwoofer)
