High output alt??
how much power do i need 2 b runnin b4 i need 2 get a higher output alt. or another battery. and what kinda battery do u recommend? im confused....
Username: Stanleyc
Post Number: 15
I think so far, Optima yellowtops would be pretty good battery to get.
Username: Donp
Detroit, MI USA
Different cars have different alternator outputs. If you have a rear defroster, chances are you have a higher amp output. You should be able to run 700 watts while running the engine. If you need to add a second battery, the Yellow Optima is a good choice.
