Lil bit of help...
Username: Tlo211
For some reason my amp doesn't get power any more... When i first turn my stero on the power light of the amp comes on for a second but then turns off. I went through and checked all my connections and checked my fuses. I also tried hookin up another amp and i still had the same problem... can anyone help me????
Username: Glasswolf
Post Number: 755
use a voltmeter.
check both the +12 and remote trigger lines for 12 volts.
also check ground point with continuity tester.
Username: Tlo211
Glasswolf... i checked for 12 volts and it was good... any other ideas on what might be goin wrong???? Thanks
Username: Glasswolf
Post Number: 782
if power to the amp is good, disconnect the speakers and see if it comes on.
if it does, ya got a bad speaker
if it doesn't, ya got a bad amp.
Username: Tlo211
already tried disconnecting the speakers, and the amp does the same thing, turns on for a second and shuts off... i've tried 3 different amps and the same sh*t happens???? its drivin my crazy
thanks
I have had a similar problem.. There was 12 volt going through the remote line when disconnected but when connected to the amp my voltmeter was only showing like 2 volts. It cleared up the next day... The temperature was about 20F so was it too cold for the amplifier to function?
Username: Tlo211
Post Number: 8
It has been below 0F for the last week or 2...
Username: Glasswolf
Post Number: 784
that's one that'd be easier if I could trouble shoot it myself. heh
yeah check remote and batter voltages at the amp when its hooked up.
something is losing voltage, or you have a short or bad ground.
