I need some help
Username: Sk8bder4life14
i am a complete newbie but i love the sound of woofers i need some help on which is a better buy i have a friend that hates audiobahn but i dont see why. On ebay they are selling a pair of audiobahn Immortal series 12" wooffers for $444. the specs on these subs are:
Impedance: Quad 2 ohms
# Dual Voice Coil: No, Quad Voice Coil
# Peak Power Handling: 8000 watts approx. Per Pair / 4000 watts approx. Each Sub
# RMS Power Handling: 4000 watts Per Pair / 2000 watts Each Sub
Surround Material: Foam Surround
Sealed Box Volume: Not Recommended
Ported Box Volume: 1.45 - 3.4 cubic ft.
Sensitivity: 95 dB
Frequency Response: 23 - 700Hz
Top Mount Depth: 8-5/8"
Cutout Diameter: 10-7
the other subs i was thing about gettin was 2 Kicker Solobaric L7 2004 model. the specs on this are way lower but the subwoofers are around the same price as the audiobahnsat $409. the specs are:
aluminum deposit cone
non-resonant aluminum basket
Santoprene rubber surround
dual 4-ohm voice coils for wiring flexibility
frequency response 20-100 Hz
power range 75-750 watts RMS (300 watts per coil)
peak power handling 1,500 watts
sensitivity 87.4 dB
top-mount depth 6-13/16"
sealed box volume 0.88-2.0 cubic feet
ported box volume 1.75-3.25 cubic feet
i mean the audiobahns sound much better but i really dont know much about woofers if someone could tell me which buy is better and why would be very helpful.
cmon someone help
Juggalo Jeff
dont even ask the people here i have no experience with audiobahn but eveyone will tell u to not get them cuz they suck so
yea that what i heard but i dont see how the kickers would be a better buy
Juggalo Jeff
Well whatever i would defnitely get the L7's cuz they r badass wattage doesnt always work when comparing two subs
how big of an amp should i go with
Juggalo Jeff
what would u get a kicker amp? Just try to match the rms of the sub with the rms of the amp like if its 750 rms per sub try to find an amp that will give that to both subs @ 4 ohms bridged
