What does ice guard look like?
Username: Jldub6
Post Number: 29
post any pics or details?
i need some material that is way cheaper than dynamat cuz i have a low low low low low low budget :-(
Username: Insearchofbass
Post Number: 817
http://www.sounddomain.com/memberpage/337124/6
Username: Jldub6
Post Number: 30
where can i purchase this?
i went to the roof section of home depot and couldnt find it :/
Username: Fishy
Tamarac, FL USA
Post Number: 345
Yeah I'm interested as well. Not much ice down here in the Sunshine State. Anything online?
I'm not much looking forward to droppin another 100 bucks on some Tsunami stuff just so I can add another layer and a half to my doors.
-Fishy
Username: Koz1031
Monticello, In United states
Post Number: 201
here is one alternative
http://www.sounddeadeningmaterial.com/home.html
here's another
http://www.coollizard.com/Lizard_main/logo.gif
Username: Erik123456
Arlington, Tx
Post Number: 146
just make sure you know that stuff takes a long time to dry you have to air your car out and put baking soda and stuff under it
its a much more involved process then dynamat etc
Username: Fishy
Tamarac, FL USA
Post Number: 350
Thanks koz. I just ordered 45 sq ft of the stuff from your first link. Looks to be nearly exactly the same thing as I bought before but at less than 1/4th the cost.
Good deal. Appreciate it.
-Fishy
[note] now that I'm gonna have a buncha dynamat like stuff, does anyone know if its worthwhile "dynamatting" plastic panels like the inside of my doorskins and such? or should I just stick to bare metal.
Username: Fishy
Tamarac, FL USA
Post Number: 356
[edit] actually its a lil less than 1/2 the cost of what I paid. I got 20 sq ft of the Tsunami stuff at Circuit City for $100. Just ordered 45 sq ft for $95 shipped.
Still a good deal especiallly compared to Dynamat.
-Fishy
Arlington, Tx
Post Number: 150
that fatmat or whatever that was posted about earlier is 99 bucks for 100 sq ft
Username: Jonathan_f
GA USA
Post Number: 2075
Try dynamatting plastic as well. Resonates nearly as bad as metal does.
Username: Fishy
Tamarac, FL USA
Post Number: 376
Thanks Jonathan. I do believe I'll try that first. Pretty sure thats whats rattlin in my doors. Just never saw anyone use it there.
-Fishy
