Glass, still have that whine
Username: Littleguy
Post Number: 13
Glass, i still have that whine in my speakers. I tried grounding everything. I noticed when i unpluge everything from my xover and run the hu striaght to the amps it go's away. I tried another xovers, both do the same. Any input on why, thanks.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7113
well that would indicate a couple of things
bad ground for the XO power supply
line driver voltage of the XO isn't set properly (if it has one)
bad XO (although that'd mean both are bad)
pinched RCA cable (very possible)
