Wires upgrade
Username: Decde
Post Number: 122
Guys, do i have to change the wiring to install new 6x9 in my car or i can run them on the factory wiring???
ThatGuyYouKnow
IF there the same type of hookup go for it
Username: Invain
Michigan United States
Post Number: 223
Your stock wires might be goofy with weird hook ups on the end of the wires. I just cut the ends off and figured out with wires were positive and negative. Worked fine.
Juggalo Jeff
yea joe smoe is right u can always use factory unless u want to customize it all
