Amp and sub wiring quest.
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 129
i have a JL12W3D4 and a Rockford P3001. Its 300x1 at 2ohms rms. my sub's vc's are run in parallel to get a two ohm load, but my quest is how to hook it to my amp. The amp has 2 sets ao terminals, 2 pos. and 2 neg. But its a mono block amp. do I hook up a pos. on one side and neg. on the other side of the amp like bridging or just hook up the pos. and neg. that are side by side? Hope yall can understand and help me.
Post Number: 136
hey
Post Number: 146
yo
Username: Southernrebel
Louisiana USA
Post Number: 224
if its a mono amp, then it just has two terminals (it acts like a distro. block so you can hook up more than one sub easily) ...like the JBL bp600.1
just hook it you to one (-) and (+)
Post Number: 148
ok thanks, I just wondering why it two terminals on a mono block, i never saw that before.
Username: Fishy
Tamarac, FL USA
Post Number: 313
like this
http://home.comcast.net/~guppyrig/wsb/media/322068/site1052.JPG
The actual positions of the positive and negative terminals on that sub are probably reversed from the diagram. I just put em that way to make it easier to draw the wiring.
good luck :-)
-Fishy
Username: Fishy
Tamarac, FL USA
Post Number: 314
There's two terminals on that monoblock for convenience sake. It can make it easier to run a pair of speakers in parallel that way. Both "positives" and "negatives" are common to each other.
-Fishy
Post Number: 150
Thanks dude.
