What amp to use for 2 12" Alpine Type-R's?
Username: Almost2asian
Post Number: 19
What amp should I use for two Alpine Type-Rs? They're rated at 300 RMS each. I'm looking to spend about 200-300 dollars, ebay prices, on an amp. Would a mono or 2-channel amp be better?
Username: Fishy
Tamarac, FL USA
Post Number: 327
Depends on which model/impedance Type-R you have.
Dou you have the dual 4 ohm voice coil, dual 2 ohm, or what?
-Fishy
Post Number: 20
well, i haven't gotten them yet, which should i get? and why? what are the advantages to each?
