Help with wiring subs? Thanks.
Username: Bernymac
Rialto, CA United States
Post Number: 14
I got two dvc 4 ohm subwoofers. I also got a rockford fosgate 800a2. 400rms x 2 channels at 2 ohms. Can someone help me find the best way to wire these subs. Should i go with the 1ohm load or 4 ohm load wiring technique? or is there something better. Thanks.
Username: Audiobahn_man
Freakmont, MI
Post Number: 155
well your amp is ratted at 2 ohms, so i would go with the 4 ohm operation, that would mean wire each sub in a series to the amp. check this site out
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
