What r the best subs???
Sweet
If money wasnt a object what would be the best subs you could buy??
depends on the application...
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 11
probably a JL audio 13w7
if u wanted an insane amount of power tho the 18 inch solo X handles 10000 watts ... and the new pioneer sub handles 5,000 but to be honest i kno nothing about the pioneer. rockford also has a sub out that handles 4,000 ... i like the stage 2's tho ... and every1 likes the Resonant engineering x.x.x subs... which arent resonant's bigest subwoofer... the MT is massive
matt77
JL X.X.X and the brahma would be prolly the best range of subs i doubt there is one best sub it all depends on the set up of everything in ur car so no system will sound the same in different cars wit diff set ups some subs will sound better then others because of this but as far as the Solo X goes that is just a big buncha crap i mean the L7 is a good SPL sub but the X is way to big and its 5000 rms just to run that big thing u could out pound that thing easy wit somethin way less watts and prolly the same wit the pioneer and rockford just cause watts are high dosn't mean it will beat really hard just look at audiobahn there the same way high watts low performance but thats what i think so u decide
Username: Thehammer
Mount Holly, Nj US
15inch Mtx Sledgehammer
Username: Audionoob13
Novi, MI USA ...
Post Number: 44
i think the audiobahn 1208t is the best, the flames on it and the chrome are the shizznit
stuff
resonant engineering mt
Username: Suicideshifter
Bristolville, Ohio United States
Post Number: 54
Don't forget the Adire Brahma...Audiobahn??? enough said...
Username: Jonathan_f
GA USA
Post Number: 2073
Eclipse Titaniums and Titanium Pros are nice too.
Username: Napalmz
MIDWEST
id max v3 up there with the rest
