Anonymous | ok, first off, i have very little rattling in my car. just a little in the doors and only on HARD hits. would sound deadening make a noticable difference in the sound of my subs? also, i have found that dynamat can get pretty expensive. i've heard of a few substitutes such as Peel N Seal and Ice Guard...do they work? are they as good as dynamat? and where can i get them??? thanks |
Silver Member Username: InvainMichigan United States Post Number: 211 Registered: Aug-04 | Yes they work. I have eDead in my car (made by elemental designs) and it works great. You should be able to find peel n seal off of their manufacturer's website. You can get Ice Guard at Home Depot. |
Silver Member Username: Pat_lTucson, AZ USA Post Number: 640 Registered: Apr-04 | try www.fatmat.com |
Gold Member Username: Jonathan_fGA USA Post Number: 2033 Registered: May-04 | edead, RAAMmat, brown bread, cascade, peel & seal, many of them out there, most are just as good. |
Silver Member Username: InsearchofbassPost Number: 804 Registered: Jun-04 | ice guard a cheap substitute to dynamat...check it out think he says 60 bucks for 108 square feet http://www.sounddomain.com/memberpage/337124/6 |
