Speakers
midtown
how many channel amp would i need to power my speakers? would i wire it up to the deck?
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 140
how many speakers do you have?
yes you would have to wire the amp to your head unit by running RCA's from the head unit to the amp.
midtown
i wanted to hook up my 6.5 components and the 6x9s in the back
Post Number: 142
so is that four speakers?
If so, a four channel amp should do the trick.
midtown
any recomendations that can put out about 100 watts rms for 4 channels?
Post Number: 143
my brother had a kicker four channel that sounded pretty good, but I dont really know of too many four channel amps. Maybe Jonathan or someone can recommend some good ones.
Username: Southernrebel
Louisiana USA
Post Number: 222
if you have 4 ohm speakers then a KX350.4 would do.
its rated for 90wrms x 4 @2ohms.
should be a pretty good match.
