Help with wiring!!!!!!!!!!!!!!
Username: Bfedro427
Post Number: 7
I have 2 Kicker CVR12's that are 4 ohms. Is there any way i can wire them to get a 2 ohm load running from my amp? Im looking to buy a new amp and need to know any way i can use 2 ohms.
Username: Boopers
Lima, Ohio United states
Post Number: 110
are they svc or dvc, if they are svc then you just run them parallel and that gives you a 2 ohm load
