Tunning my box, Sean or Jon i need your help!!!
Username: Audiobahn_man
Freakmont, MI
Post Number: 121
I have a 5 cubic foot box i made for 2 cerwin vega 12'' V-Max's, and i have 10 ft of 4 inch pipe, the specs say to have 3.5 inch pipe but 4 was the clostest that i could find( I have a contracters licence at ACE, so if i need to get a dif size i can just go get it for free)So my question is how many and how long should i have the ports, Also, how would i flare the ends? Needs to be tuned to close to 33-35 range, THANKX!
Username: Insearchofbass
Post Number: 770
5.00 cf minus displacement for woofers should put you at about 34 hz with three 4 inch ports 15.75 inches deep and nice and low on port resistance
Username: Koz1031
Monticello, In United states
Post Number: 176
does this sound familiar sean?
Steven: don't forget to radius the interior part of the pipe, or you could stand a good chance of getting port noise. keep the ports at least 4 inches from the edge of the box, and 5 inches from the sub. other than that, as sean's dimension appear to be right, you should be good to go. happy bummpin!!!!!!!!!!!!!
Freakmont, MI
Post Number: 126
thankx for the help guys!!!!!!!!!
Freakmont, MI
Post Number: 127
another question, what if i added another port, would that shorten it?? And can i put the ports on the side of the box??
Im about to make it right now and i need the info asap!
Freakmont, MI
Post Number: 128
could i just have 2 ports and have them both 10'' deep?
Freakmont, MI
Post Number: 133
ok, i ended up with a 4.3 cubic foot box, 2- 4'' ports 10'' long, 1 inch (before stapled) of fiberglass insulation on every side but the side the subs and ports are on. That work good?
Post Number: 773
yes you can run 2 ports with 4 inch pvc 9.5 inches deep for a 34 hz tune port volocity will still be low enough (.08 and it should be no higher than .16) put the ports on the front of the box or the top
Post Number: 774
we posted the same time let me check lol
Post Number: 775
if thats 4.30 cf before the insulation it will be 36 hz after the subs and ports and if that after insulation it will be about 37 hz
Post Number: 776
steven if you want the port tune lower do another layer of insulation it will add 10% box volume airspace boost
Post Number: 777
ok repost here i used wrong port length if its 4.30 after insulation its 36 hz if its 4.30 before insulation its 34.4 hz
Freakmont, MI
Post Number: 136
It was 4.333336 somthing before insulation, then i stapled about an inch thick of fiberglass insulation on every side but the subs, then i put 2-4'' by 10'' long ports on the front between the subs
Post Number: 788
still should be about a 35 hz tune with the insulation accounted for and subwoofer displacement and ports .....do another inch thick insulation and you will be at 33 hz port tune after displacements with decent port volocity (.08)
Freakmont, MI
Post Number: 138
yea, after i maxxed it out, i had some major port noise(well if you put your ear close to the ports), and the only way i can change the ports is to make a new box, any suggestions? And sean your my new best friend :P
Post Number: 790
posted by koz
me....if this doesnt work we can do the 3 four inch ports
