What configuration do i need
i want to buy 2 re se x x x i want to wire these in 2 ohm...do i want to get dual 2 ohm or what...thanks
if you buy dual 2-ohm voice coil subs, you can wire the coils of each sub in series and the subs together in parallel for 2 ohms overall. just run 2 wires from the amp, one to a + contact on each sub. then run a wire from the - of the same coil (usually the contact right next to it) to the + of the other coil. repeat this for the other sub. then run 2 wires, one from each remaining - contact to the amp.
now that i've written all that... i found a diagram: http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC2x2
do option 2.
