Posted on Is it possible to wire 2 subs that have a dual 4ohm vc and have it come out to a 2ohm load at the amp? Thanks! |
Silver Member Username: Symplestiles
Stockton,
CA
Usa
Post Number: 191 Registered: Aug-04
Posted on i think 2 DVC 4 ohm subs would wire down to a 1 ohm load, not 2. however 2 SVC 4 ohm subs would wire down to that 2 ohm load your lookin for |
Juggalo Jeff Unregistered guest |
Posted on i had the same question i figure if they r on seperate channels it will be 2ohms for each sub |
