SEALED OR PORTED
Username: Jeremy_c
Kirksville, MO USA
is it beter to have a bass port or are sealed boxes the why to go
Username: Chevy_for_life
Post Number: 11
Notta clue...
Username: Stream
Arkansas
Post Number: 21
Generally, you'll get more SPL with a ported box. Most people would agree that sealed boxes are better for SQ, as you get much tighter, cleaner, and crisper bass.
I also think that ported boxes tend to sound a little muddy and fluffy, unless you have a professionally-tuned box (which I don't).
Ported boxes are also much bigger than sealed boxes. The average sealed box is under 1 cubic foot, while a ported box for the same sub can be nearly as big as you want (5 or 6 cubic feet, or more), within reason.
-Jesse
Username: A3forme
Post Number: 305
You can get good SQ from a ported box if done right. But you typically only get a 3db gain from sealed to ported. As said above sealed is smaller and have tight low bass. Nothing like an Eclipse Ti sealed. (although I love my ID Max's)
