QUICK Qestion. ebay auction ending, which subs better 2 shivas or 2 fosgate subs Specs Here Thanks
Username: Forcesofchaos
Post Number: 31
ok so what you think any suggestions would help.
2 x Adire Audio Shiva Subwoofer MkIV
SPL 87.3 dB @ 1W/1m
No 0.37%
Pmax 375W per voice coil; 650W total to the driver
Distortion <3%, 16 Hz - 200 Hz, @ 100 dB SP
http://www.acoustic-visions.com/~acoustic/products/subwoofer_drivers/adire_shiva /
or 2 x Rockford Fosgate RFD2212 12"
Rockford Fosgate RFP2212 12" Punch HX2 Subwoofer:
* Two 3" 4 Layer LXtended Voice Coils
* Coil on Aluminum Former
* FIBERLock Cone
* Hyper XTended Pole Piece
* LXcursion Cast Frame
* Dual Laminated Progressive Flat Spider
* BART Surround
* CONsealer gasket hides mounting screws and provides an airtight seal
* Aeroport Exhaust
* Rubber Magnet Boot
* Dual 4 Ohm voice coils
* Frequency response 26-200 Hz
* RMS power handling: 500 watts each sub
* peak power handling: 1000 watts each sub
* Sensitivity 88 dB SPL
* Top mount depth 5-13/16"
* Sealed box volume 0.8-4.0 cubic feet
* 1-year Sonic Electronix warranty
thanks,
suggestions know that 1 brand is good or anything would hlep thanks
Username: Pat_l
Tucson, AZ USA
Post Number: 614
I would say go with the shivas, i am not a fan of RF P2 or P1, even though i love Rockford. I think you would be much happier with shivas.
If you could find P3 or T series, that would be neat
Post Number: 36
yah ill stick with shivas it has a higher spl rating and better frequency response i think though they are 8 0hms ill wire them to 2, ill find a way. double coils shouldnt be that hard.
